Can you identify the wires in my o2 sensor? - Fuelly Forums
Old 06-11-2006, 11:24 AM   #1
Matt Timion's Avatar
I am installing a d15z1 into my 89 LX. I purchased a wiring harness from rywire and I'm currently wiring up the o2 sensor. It's a five wire o2 sensor, so keep that in mind.
here is a picture of my o2 sensor with the colors:
The instructions from rywire were as follows:
LAF Sensor
-yel/blk o2 heater brown wire in pigtail
-black wire ground (use purple wire in pigtail harness)
-green/white ground (use purple wire in pigtail harness)
-white D3 (red wire in pigtail)
-white/blue D8 (use pigtail orange wire)
-orange/blue D14 (use stock 1 wire o2 wire for this position)
-orange D16 (grey wire in pigtail)
The colors are not matching up, and I don't want to make any assumptions.
Can anyone tell me the functions, or the pin positions of the o2 sensor based on the colors in the above picture?
Old 06-11-2006, 12:37 PM   #2
krousdb's Avatar
Terminal Location / Description
1 - Heater Positive
2 - Chassis Ground
3 - ECM Ground
4 - Label Resistance Input
5 - Blank
6 - Cell Voltage Input
7 - Pump Cell Control
8 - Reference Voltage
The wire colors changed a lot, but all of the terminal locations in the LAF connector stayed the same.
Old 06-11-2006, 12:38 PM   #3
You so crazy, Dan. You need your own computer, by the way.
Old 06-11-2006, 12:42 PM   #4
1 - Heater Positive
2 - Chassis Ground
3 - ECM Ground
5 - Blank
What exactly do these numbers mean? there are only 5 wires on my sensor.
Old 06-11-2006, 12:43 PM   #5
krousdb's Avatar
One other note about the LAF sensor wiring is that you will find 7 wires on the engine side wiring harness and 7 termninals in the LAF connector, but only 5 wires from the connector to the LAF sensor. Two of the terminals are connected to a calibrating resistor that is located in the LAF terminal. This resistor is typically 4.3K ohms.
Old 06-11-2006, 05:42 PM   #6
Is this on the engine harness side or the oxygen sensor side? I'm going to be using a 8-wire plug from a obd1 distributor and not the actual oxygen sensor plug. Images are as follows:
Here is the plug I'm using (sorry so blurry)
And a picture I made to help with the discussion:
Old 06-11-2006, 07:32 PM   #7
Jared just helped...
# = c107(dizzy) = c111(o2)
1 = orn = wht
2 = orn/blu = grn/wht
3 = blu/grn = blk
4 = yel/grn = yel/blk
5 = wht = orn
6 = wht/blu = orn/blu
7 = blu/yel = wht/blu
8 = \ = \
Thanks jared !
Old 06-11-2006, 07:34 PM   #8
|V3|2D
thisisntjared's Avatar
Thanks jared !
:thumbsup: thank my grandparents for buying me the honda manual way back on my 21st b-day
Old 06-11-2006, 07:48 PM   #9
thanks g-parents.
BTW, my brother got me a n600 chilton manual for christmas. how cool is that?
Old 07-11-2007, 11:13 PM   #10
1 - Heater Positive orange Yellow/Black A6
3 - Chassis Ground yellow Black A23
5 - ECM Ground looped back to 7 Green/White N/A
7 - Label Resistance Input looped back to 5 White N/A
2- Blank
4 - Cell Voltage Input red White/Blue D8
6 - Pump Cell Control white Orange/Blue D14
8 - Reference Voltage black Orange D16
mcamodell is offline   Reply With Quote
First Fuel Up, New car RuiGomes Fuelly Web Support and Community News 1 11-23-2012 03:51 AM
Can fuel descriptions associate with mileage at *next* fuel-up? anthill Fuelly Web Support and Community News 2 01-30-2011 10:32 AM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
