Camaro Starting Issues - Page 4 - Fuelly Forums
Old 07-29-2011, 06:46 AM   #31
Re: Camaro Starting Issues
Vapors can and should be arriving in the intake, but I'm not sure of any way for them to reach the oil that hasn't already been discussed.
GM did have a redesign for that solenoid. Was your original one a rectangle/box shape and the new one a cylinder shape?
Old 07-29-2011, 07:01 AM   #32
if cookies will allow...
old...http://www.autozone.com/autozone/par...er=124311_0_0_
new...http://shop.advanceautoparts.com/web...purge+solenoid
Old 07-29-2011, 08:18 AM   #33
Cookies didn't allow the new one.
Anyway I think I screwed that up, I was talking about the vent solenoid and you're talking about the purge solenoid...we may even have had this discussion before. D'oh! Stupid me.
Old 07-29-2011, 12:25 PM   #34
well, in short...
the new one has the inlet and outlet at opposite ends, while the old one had them both at one end.
Old 08-01-2011, 08:47 PM   #35
Dr. Jerryrigger's Avatar
I'm just reading this now, but when you said it started fine if you opened it up, I though leaky injectors. If it was a bad check valve on the pump the throttle wouldn't help at all, it would just add more air to a too lean condition.
Despite what your mechanic said, a fuel system should always have pressure. It should change very little from when you turn it off, to when you start it a few days later. If it's dropping off then there is a leak somewhere. If your not smelling it, then it's likely at one of the ends, pump or injectors.
A easy test: If you crank it and it doesn't start, sniff the tale pipe. If it smells like unburned fuel then you are getting some fuel. This will let you know it's a leaky injector or an ignition problem.
If you prime the system and it starts off running crappy like one cylinder is missing this is also a sine of a leaky injector. The cylinder it's leaking in to has too much fuel to burn. This shouldn't last very long though, as it will pump it out in a few revolutions.
If it was my car (I'm not recommending you do this), I'd let it sit for a few hours after running. Maybe prime the fuel system a few time during this time. Then pull all the plugs and sniff test each hole. I bet one will smell much stronger.
Oxygen Sensor? Nate R General Fuel Topics 3 04-09-2008 04:47 PM
Install a vacuum gauge for better mpg? kozaz General Fuel Topics 4 11-13-2007 07:07 PM
Pictures posted garyhgaryh General Maintenance and Repair 1 10-27-2007 08:57 AM
Car trouble woes Fourthbean General Maintenance and Repair 10 07-30-2007 05:54 AM
Mazda3 S Touring psyshack Introduce Yourself - New member Welcome 12 07-17-2007 09:34 AM
