Buying an EFIE - Fuelly Forums
Old 06-17-2008, 06:27 AM   #1
Buying an EFIE
I got a EFIE board from fuelsaver-mpg today. Most of it was fine. The LM2940s chip is not completely on the pad. One problem is too much. It only takes one short to cause problems. Will it work? Probably. The run is coated so it should. Could it short...maybe. Do you want a maybe problem attached to your cars ECU?
Notice the three legged chip....designation LM2940s. The chip is over a run...it does not sit completely over the pad. This is not a good thing. I'm not real happy with their work.
cugir321 is offline   Reply With Quote
Old 06-17-2008, 06:49 AM   #2
GasSavers_BEEF's Avatar
you can always put it on a hotplate and move it. or maybe even use a hot airgun and move it yourself. I work in electronics so I have access to quite a bit of soldering equipment. sometimes I take it for granted.
if you art that concerned about it you can always send it back or just get one from somewhere else.
Old 06-17-2008, 07:52 AM   #3
if it helps any (and it might not) here is the data sheet for the part you are worried about.
http://datasheet.digchip.com/064/064-01134-0-LM2940.pdf
*edit* and the tab is ground, crap, I see your delema.
Old 06-17-2008, 11:11 AM   #4
Beef, Do you by any chance make EFIE's? If you do how much do they sell for? I have a couple of schematics for them, but what I know about electrical components is just enough to get someone hurt or ruin more than I would fix.
Hipermiler
#47 on my way to #1
Old 06-17-2008, 02:04 PM   #5
sorry, no, I work for a company that designs and manufactures amplifiers for cell phones.
I have been in the business for a while and done quite a bit of soldering in my time. I have also worked in repair so I am kind of used to looking up part numbers and data sheets.
Old 06-17-2008, 06:41 PM   #6
move it
I know I can move it....it does have very small surface mount chips on the back side of the board. Below the LM chip. Get it too hot and they drop off. But that's not the nut of it. It's a 45.00 board....would have taken 30 seconds for them to spot the chip. 3 minutes to fix it with no chips on the back side. Now I have to deal with it. I bought the board so I didn't have to spend my time putting it together. I did my pwm...I didn't feel like spending the 3 hours to put it together. I've seen shorts in the exact type situation in the Navy.
Now I have to pay with my time...send it back...time...fix it....time. There's no excuse for that chip.
Old 06-18-2008, 04:28 AM   #7
quality control isn't what it used to be.
just out of curiosity....was there a "MADE IN CHINA" sticker on that board?
I say to send it back and raise cane. you may at least get free shipping out of the deal.
Old 06-18-2008, 10:32 AM   #8
I would send it back for repair or replacement. If they get by with it this time they will be less likely to improve the quality of their work. Yes, it will cost you some time, but it is better than coming up 2 months from now needing a complete new board due to manufacture negligence.
Hipermiler
#47 on my way to #1
Old 06-18-2008, 10:39 AM   #9
For the Record:
I am the owner of FuelSaver-MPG. I have already offered to replace the board or refund your money. At your choice. If you hate it, just send it back. I'll refund you in full. Or, if you want, I'll send you another one, and I'll make sure the voltage regulator is on straight. I know the board works, because I test each one before it ships.
I stand behind every product I put out. You're the first unsatisfied customer I've ever had. You must have some other motive. Otherwise you wouldn't have ignored my offer to replace or refund at your choice.
mikekehrli is offline   Reply With Quote
Old 06-18-2008, 11:04 AM   #10
Yea right
These people here have seen enough of my posts to know my motives. Yea right! First unsatisfied customer!!! What I hate is that if I didn't know what I was looking at you probably would have said, if your not happy with it then we have a nice forum where you can sell it yourself.
Then you're to blame!....you tested it?...why didn't you look at the unit before you shipped it?
Fine....you want to make it right. Refund the full amount with shipping. I keep the unit. I'm not going to be bothered packing it and sending it out...more postage. I know what the parts cost. You've sent it out without checking it and inconvienced me....take the loss.
Okay, here you go, I'm fair, you want to make it right...refund the cost of the unit, initial postage, return postage, 10.00 for my time and energy to repackage it and send it. When I see it on my card I'll send it back.
Funny, you misplace a chip the size of arizona onto your circuit board so there is a possibility of short at some later date, sell it, and then try and blame the customer of a motive. Boy, that's a fine company!
quick fix of a shallow dent 1993CivicVX Experiments, Modifications and DIY 2 08-19-2007 06:22 PM
Just a heads up.... atomicradish General Fuel Topics 11 07-08-2007 12:55 PM
New member /2007 Prius billynjoanna Introduce Yourself - New member Welcome 10 06-09-2007 11:56 AM
