Buying an EFIE - Fuelly Forums
Old 06-18-2008, 10:47 AM   #13
Like Mike
Now, should I respond to this like Mike did?
Originally Posted by Sludgy View Post
I never looked at EFIEs before seeing this string. The basic idea is a good one, causing the engine to run leaner by altering the O2 sensor signal.
I know that the manufacturer states that it will not improve mileage without other engine mods, but leaning out an engine always increases efficiency, in two ways: More air is brough into the engine at a constant fuleing rate, lowering vacuum/throttle losses; and excess oxygen improves combustion efficiency, releasing heat that is otherwise locked up in exhaust CO, HC and H2 from a stoichiometric A/F mix. (It comes at the expense of NOx emissions, however. Three way catalysts need HC and CO to reduce NOx.)
You guys should stop feuding, the guy is making a worthwhile product nobody else does.
cugir321 is offline   Reply With Quote
quick fix of a shallow dent 1993CivicVX Experiments, Modifications and DIY 2 08-19-2007 05:22 PM
Just a heads up.... atomicradish General Fuel Topics 11 07-08-2007 11:55 AM
New member /2007 Prius billynjoanna Introduce Yourself - New member Welcome 10 06-09-2007 10:56 AM
