budomove's KFA d15b8 mpfi swap log - Fuelly Forums
Old 06-28-2006, 09:07 PM   #1
I am hoping to kick frank's a$$, yeah I'm frank.
I want to swap to a b8 from my 16 valve b1.
SVO tells me i need:
dizzy (he's got one)
ecu (he's got it)
injector clips (thanks matt)
The swap would come with mpfi, and i would modify my own harness, hopefully.
I was first thinking of a simple head swap, but SVO has informed me it would be better to swap a whole engine. i.e. less gaskets to buy/worry about
Edit: Just realized my back might not like an entire engine swap. SVO, did you have to lift your engine ever?
budomove is offline   Reply With Quote
Old 06-28-2006, 09:11 PM   #2
You'll also need a throttle body, as the swap is missing that.
Anyway, I'm thinking of compiling a full list of what we need to get this crap done, so lemme type for a few minutes.
Old 06-28-2006, 09:15 PM   #3
Okee, MPFI/OBD1/D15B8 Swap List:
Longblock
OBD1 Distributor
P05 ECU
IM/TB
Injector Clips
Wire
Electrical Tape
Shrink Wrap
Spare Soldering Iron Tip
Wire Loom
Fix my Valve Cover to Trade You
Water Pump
Timing Belt
Alternator Belt
OBD1 Ecu Plugs
Drain Pan for Coolant
That's all I can think of right now, water pump/timing belt is a good thing to do before the engine goes in.
Old 06-28-2006, 09:17 PM   #4
To your edit, I had my back seriously hurt for about three weeks from improper lifting of that b8 engine. But we'll find a hoist somewhere, no worries.
Old 06-28-2006, 09:17 PM   #5
I just put water pump/timing belt/alt belt on last month, all new parts...think they're compatible? Nice list, by the way.
Old 06-28-2006, 09:20 PM   #6
They ought to be, We can just put the timing belt up next to the old one and see.
Old 06-28-2006, 09:22 PM   #7
Nice. Your back ok now? I am just worrying about getting it in and out of my car to put on hoist. That is when I can't imagine a way around lifting it. What do you think?
Old 06-28-2006, 09:25 PM   #8
Hmm, I lost my reply, but anyway, I only hurt myself not thinking, but I totally stripped the engine also.
Anyway, we can double up on picking it up.
Old 06-28-2006, 09:29 PM   #9
If you are still around, and willing, that would certainly be awesome. We'll see I guess, that's how I ruptured a disc though, picking up the wrong way how you did. Any idea how much the engine weighs? 200-250 lbs, maybe?
Old 06-28-2006, 09:33 PM   #10
duplicate post
Fuel cost constraint problem mileoresko Fuelly Web Support and Community News 6 03-11-2009 01:33 AM
More vehicle models EmptyH Fuelly Web Support and Community News 2 08-18-2008 06:13 AM
what will the scangauge fit? GasSavers_Ryland Hypermiling 11 03-29-2006 07:15 PM
