Bought a car for FE but im having trouble need Mech help!!! - Page 2 - Fuelly Forums
Old 03-09-2008, 02:20 PM   #1
Tepco's Avatar
I posted this exact question on other sites with mixed answers, so i would like to try it here. The car got 36mpg on the first 1/2 tank. Now im driving more efficiently but my mpg is dropping.
Please take a gander and tell me what you think.
My question is my 1989 Civic HB D15b2 that is smoking when i rev it or excellerate hard. Its burning about 1/2 Qt every 200 miles. It's leaking from the dist the normal amount.
Here is some engine info.
I just purchased it for a commuter, it was a one owner daily driver, it has 217k. i bought it with a seized cam. i replaced the head with a head off of a 1993 DX with between 100-150K, and had it milled and torqued to the TSB specs and all new gaskets, the cylinders still had cross hatch marks on them. ( i didnt talk to the owner so i dont know the full history of the engine)
New timing belt, water pump, plugs, PCV valve.
Starts and runs great and as strong as i would think a 1.5 could be.
Dry compression check showed, from dist. to timing belt:
180 185 170 180
Leak Down
4% 4% 5% 4%
The car appeared to be running for quite some time with a leaking head gasket. When i replaced the PCV valve i noticed a build up of carboned oil on the hose connecting the PCV valve, although air flowed through the line fairly easily.
I hate posts that lack info so i hope i listed enough.
Please let me know what else i could check or what else it may be.
Thanks,
Tim
Gas?? Oh you mean the expensive smelly stuff Grandpa used to power his car with? Silly old Man.
Get off my @ss I'm saving gas!!
Tepco is offline   Reply With Quote
VW pickup VetteOwner General Discussion (Off-Topic) 6 06-08-2007 09:45 AM
DIY: Wire Tuck!!! SVOboy Experiments, Modifications and DIY 11 09-21-2006 04:17 AM
12 Honda Beats for sale in Canada Matt Timion For Sale 8 09-17-2006 10:27 PM
