bicycle speedometer on dumptruck? - Fuelly Forums
Old 06-11-2010, 08:51 AM   #1
my dumptruck speedometer doesn't work. I want to use a bicycle speedometer. will a wireless model be effected by my nonresistor sparkplugs? A wired model would need the wires lengthened, so I would prefer the wireless model.
mikehallbackhoe is offline   Reply With Quote
Old 06-11-2010, 09:01 AM   #2
Are the tires on your truck the same diameter as the bicycle tire that speedometer is designed for? If not it will not give an accurate reading. I also have doubts that a wireless bike speedometer would have the strength to push signal through the cab of a truck. In most instances a typical setup for that device would only be 2 or 3 feet away, with no obstructions. I also wonder if it will stand up to the sustained road speeds that a truck achieves.
Old 06-11-2010, 09:31 AM   #3
the bicycle speedometer will work with any size tire. you mount the magnet near the rim or brake drum, measure the tire diameter, and and enter the info into the computor. the bicycle speedometor will be accurate to speeds much higher than my dumptruck is cabable of going. I have seen them used on motorcycles, and they are very accurate. much cheaper than a gps, my second choice.
Old 06-11-2010, 09:43 AM   #4
Awesome idea. I'd use a wired one for reliability and lower cost though.
I may use this idea on an upcoming project...
Old 06-12-2010, 08:51 AM   #5
hmm
how small of a diameter can they go? (thinking of racing lawnmower spedometer)
but really is it that hard to find a replacement spedometer for a dumptruck?
Old 06-12-2010, 12:51 PM   #6
hmm
they would work on a racing lawn mower, and only cost around 30 bucks. fixing a speedometer on a 36 year old dumptruck is not easy to do, and will cost much more than 30 bucks. an over 30 dumptruck is like working on a 10 year old computor, you might as well be working on a model T
iphone experience bearmeister Fuelly Web Support and Community News 5 02-10-2010 11:25 PM
VX wheels with tires for sale evan.heidtmann For Sale 0 09-26-2009 11:59 AM
XR-3 Triike => New Tri-Magnum? cfg83 Car Reviews 1 07-12-2007 05:30 PM
HI All! newbie GasSavers_Asif Introduce Yourself - New member Welcome 2 06-05-2007 11:14 PM
Mitsu... tomauto Electric and Solar powered 0 10-10-2006 09:26 PM
