Be careful using abrasive pads to clean head gasket residue - Fuelly Forums
Old 08-14-2008, 12:56 PM   #1
GasSavers_Erik's Avatar
I always hate how it takes 2+ hours to clean head gasket residue off a block, so I took the advice of an auto parts store manager and tried those little abrasive disks that you can spin with a drill.
Things were going fine until I scratched the top of the cast iron sleeve.
The small scratch ran out from the cylinder toward the cooling jacket so I knew the solid metal ring on the head gasket wouldn't seal it. By the time I had polished it out with 400 grit sandpaper, I had taken .002 inch off that spot (as measured with a straight edge). The tip of the screwdriver points to the spot.
I was too nervous about the new head gasket sealing this "divot" so I decided to play it safe and get it flat. I had to strip the block and take it in to the machine shop to get the deck refinished.
So, just take your time and spend the 2 hours scraping the head gasket residue off with a razor blade and maybe a little steel wool. Otherwise, you might spend an extra 4-6 hours and an extra $50 to get the block machined. Thankfully I already had this block out on an engine stand when I messed it up.
Another issue that I have read about (after the fact) is the abrasive grit that these pads will leave behind in your cylinders.
Moral- shortcuts can waste lots of time
Old 08-14-2008, 01:00 PM   #2
|V3|2D
thisisntjared's Avatar
wow that sucks!!!!! fortunately i dont plan on ever taking the head off my honda...
Old 08-14-2008, 02:29 PM   #3
palemelanesian's Avatar
Hey - you raised your compression for better performance!
Good reminder, thanks.
Old 08-14-2008, 02:51 PM   #4
Next time use solvents!
Old 08-14-2008, 03:24 PM   #5
I have read several places and been told by knowledgeable experienced people to never use abrasive pads to clean a head or any other mating surface for exactly the reason your post illustratates. solvents and razors (or other suitable hard flat sharp edge), no matter how long it takes.
mini-e is offline   Reply With Quote
Old 08-14-2008, 04:49 PM   #6
don't forget to take the rags out, I've seen people forget and leave them in intakes, the rag wrapped around the camshaft on a v-8 and broke it. or someone got one sucked down the intake and into the cly. I only use the abrasive disks on iron blocks, alum parts we should use a chemical that loosens the gasket and using an old ice scraper(plastic is good) it comes right off. or a brass scraper not hard metal. they do make soft abrasive disks but that takes forever to remove gaskets.
Old 08-14-2008, 08:16 PM   #7
kamesama980's Avatar
^^^yea a razor blade can carve right through aluminum... not that I'd know
on my cressida, I spent about 4 hours on the block and more on the head but it's a straight 6.
-Russell
Old 08-15-2008, 05:33 AM   #8
djenyc's Avatar
I always used abrasive, both when working in a shop and on my own cars - never a problem.
However, I would not recommend doing it with a drill, as in that application it's to awkward to hold and you don't have the control you need. Just get an air angle grinder for ~$20 like this:http://www.harborfreight.com/cpi/cta...emnumber=93157 I've used it on many engines - cars, bikes, outboards - you name it.
Ross
djenyc is offline   Reply With Quote
Old 08-15-2008, 11:26 AM   #9
Danronian's Avatar
Razor-blades are scary with the aluminum parts. I've never used the abrasive disks personally but I have used some course steel-wool. Never had a sealing problem afterward. I should have used some solvent though, that is something I will do next time for those aluminum surfaces.
Old 08-17-2008, 09:45 PM   #10
bockwho's Avatar
Just to throw this out their .. these work great ive used them for years.
http://www.fundeals4u.com/3M_2_Scotc.../twmmm7528.htm
the scotch bright disks you have in the photo look very course.. they make some really fine ones. that we use to buff out dents and scrapes on airplanes.
be care full with razorblades also. we have a nice assortment of plastic scrapers since you cant scrape airplanes with metal scrapers or razorblades.
[/url]
bockwho is offline   Reply With Quote
Takin' the Vortekz plunge SL8Brick Aerodynamics 32 03-04-2008 12:00 PM
Hey whats up people superrican Introduce Yourself - New member Welcome 1 02-10-2008 11:27 AM
Fuel Economy Run information GasSavers_Graeme General Fuel Topics 2 01-16-2008 02:28 PM
Greetings from the SF Bay area! spazzer Introduce Yourself - New member Welcome 2 01-01-2008 08:05 PM
Best Saturn RUn HEK General Fuel Topics 7 07-11-2007 11:49 AM
