Are pre-lubers worth it? - Page 2 - Fuelly Forums
Old 04-08-2009, 08:41 PM   #11
Switch to Synlube and you won't have to worry about startup lubrication since is binds to the parts and is always there to lubricate. There is metal to metal on the rings when conventional oils are used since they rely on the oil film to float the rings and since that only happens when the rings are moving you will not have lubrication at top and bottom of the stroke or when not rotating/moving.
Old 04-09-2009, 06:33 AM   #12
I don't remember that one, but if they took all the badges off the car they really don't need Dodge's permission.
Old 04-12-2009, 10:45 PM   #13
Member
Geonerd's Avatar
Invest a few dollars in a high quality filter, with a well designed anti-drainback valve. (Eg. avoid the radioactive 'Orange Can of Death.') PureOne, Wix, Mobil, and several other 6~10$ filters are well built, and generally have a well designed, functional ADBV. You don't want the engine starving while an empty filter delays oil flow.
If you live in a cold climate, buy a block heater, and use 0w-x oil in winter. Look at the oil's pour point - the lower the better.
Those cars that were run w/o oil may have kept going, but I'm sure they were VERY torn up...
Geonerd is offline   Reply With Quote
97 Saturn SL1 with cracked SOHC head- can I do a DOHC engine conversion? GasSavers_Erik General Maintenance and Repair 6 05-28-2008 10:25 AM
dead battery? lunarhighway General Maintenance and Repair 8 12-20-2007 02:07 AM
Howdy! es330td Introduce Yourself - New member Welcome 1 11-20-2007 03:03 PM
More need for computer help Rstb88 General Discussion (Off-Topic) 2 01-31-2007 07:30 PM
