Anyone willing to loan a tach? - Fuelly Forums
Old 09-11-2011, 02:16 PM   #1
Hello all,
My friend and I both have 94 civics and need to adjust the idle. I was wondering if anyone had a digital tach they would be willing to rent out through paypal or something. The cheapest ones I can find are more than $40 and that is a lot for a one time job. I realize I'm new to the site but thought I would ask anyway. I have seen the inexpensive ones that use reflective tape but don't know how well they work. Thanks.
honerscivic is offline   Reply With Quote
Old 09-11-2011, 04:14 PM   #2
Re: Anyone willing to loan a tach?
well if its a one time deal and you get the tape to stick at the right spot then i wouldnt see a problem with em...you MAY be able to buy a cheap $30 or less auto tach and wire it up and get the rpm signal thru the AHDL connector for a temp quick solution...
have you checked www.harborfreight.com for anything?
Old 09-11-2011, 11:02 PM   #3
Harbor Freight has a 2" tach for $19.99.
http://www.harborfreight.com/catalog...t?q=tachometer
Hipermiler
#47 on my way to #1
Old 09-14-2011, 03:33 PM   #4
I bought the DMM with inductive clamp from harbor freight and it does not work right. I want a digital read out so I guess I will try one of those reflective ones. Thanks for the suggestions.
Old 09-14-2011, 06:27 PM   #5
GasSavers_Erik's Avatar
Perhaps you could just adjust the idle to the lowest rpm that it will still stay running even with the lights on and the blower fan running.
just bought my 2nd VX redEGG Introduce Yourself - New member Welcome 6 04-22-2009 07:54 AM
If you could rent an NSX or Beat, which would you pick? MetroMPG General Discussion (Off-Topic) 25 08-12-2007 06:46 AM
Sugar in the gas tank [Alternative Fuels] Rick Rae Automotive News, Articles and Products 4 07-27-2007 05:59 AM
To the wiring experts......modifying factory CC cfg83 General Maintenance and Repair 1 07-24-2007 05:43 PM
eBay: 1982 Ford pickup Electravan MetroMPG Electric and Solar powered 2 06-24-2007 07:34 PM
