Any idea how to get rid of a vacuum leak? - Fuelly Forums
Old 01-06-2006, 09:00 PM   #1
Compaq888's Avatar
Sometimes When I'm standing at a light the rpm dips to 500rpms or when I'm driving under 10mph and I stop it dips to 500rpm. I've had this problem since I bought the car.
Old 01-06-2006, 09:26 PM   #2
Matt Timion's Avatar
like I told you in IM, I'd
like I told you in IM, I'd replace any vacuum hoses with holes in them. Hell, replace them all to be safe.
I'd also check your Idle Air Control Valve, which might need replacing or just a good cleaning with carb cleaner.
Another area where you coudl have a vacuum leak is your PCV valve. you can always get a new one for $5. Check all of your gaskets on your intake manifold (throttle body, pcv, etc.)
Old 01-09-2006, 07:34 AM   #3
Moderator
GasSavers_DaX's Avatar
Yep, just go to AutoZone and
Yep, just go to AutoZone and buy about 6 feet of vacuum hose. Replace them one at a time so you don't get confused. Easiest way.
Also, check if you intake manifold gasket is leaking by spraying carb cleaner around the gasket - if your engine tone changes, you have a leak.
Publishing Fill-up Stats from Mobile Site? smknipe Fuelly Web Support and Community News 2 06-22-2011 05:27 AM
Average Number of Fuel-Ups Incorrect? grateful Fuelly Web Support and Community News 7 06-20-2011 12:51 AM
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 03:48 AM
More Fuelly graphics? reppact Fuelly Web Support and Community News 5 11-30-2008 08:07 PM
