Adding A/C to a non A/C VX?! - Fuelly Forums
Old 10-22-2007, 06:38 PM   #1
smccall's Avatar
What would it take and would it be worth it to add A/C to a non A/C Civic VX? I live in Georgia and it gets hot down here.
Old 10-22-2007, 06:47 PM   #2
garyhgaryh's Avatar
I have a non-working AC on my VX which I'm trying to get working again.
The prev owner said the compressor sparks. I'm looking for a compressor - anyone have one here for sale?
Gary
garyhgaryh is offline   Reply With Quote
Old 10-22-2007, 07:35 PM   #3
smccall's Avatar
Gary
You have A/C already in from the factory, but I'm wondering if its possible for a non A/C civic VX.
Old 10-22-2007, 08:13 PM   #4
GasSavers_TomO's Avatar
Yes, it is possible. If you go all new parts from Honda, it'd be about $800 for all the wiring harnesses, compressor, evaporator, condensor, fan, button, etc.
Honda Civic VX Info/Links
Old 10-22-2007, 08:23 PM   #5
smccall's Avatar
Since you are the King of VXs, would you happen to have a write up on doing this? What parts could I get from a junkyard and which ones would be better to get new?
Old 10-23-2007, 02:16 PM   #6
jadziasman's Avatar
If the VX has never had A/C, it will take a lot of work installing all the A/C lines, condenser, compressor and evaporator. My current 92 VX had A/C but the compressor was taken out well before I bought it in 2005 (probably because it didn't work any more). I bought a used compressor and installed it myself. It was still difficult because all the o-rings needed to be replaced for the conversion from R-12 to R-134a and I needed to buy tools I didn't have - a vacuum pump for $100 and manifold gauge for $30. You can do it if you have the time and $$$$ but be sure to inspect the liquid lines (they're the thin aluminum pipes) carefully for leaks before charging with R-134a. I had a liquid line that had a tiny pin hole in it from corrosion that I didn't spot because it was underneath the insulation that covers the line. I needed to replace it after I had already worked on the A/C in April 2006. The repair was done later in August 2006 and that was really difficult to do in the 90+ heat.
If you can, get an A/C system out of a 94 or 95 civic. The condensor and compressor are not interchangeable for the R-12 (92 & 93 Civic) and R-134a (94 & 95 Civic) systems BTW.
Old 10-23-2007, 04:23 PM   #7
You can do it. I would suggest you hook up with someone who is maybe already removing one, because of weight.
What I did was to go the pick a part yard, when they had a 50% off sale. Then I found a Honda of the years I was looking for and pulled all of my parts off of that car. When you install it, I would recommend putting in new o-rings and new oil, for R134. You can use R134 in an R12 system, but you would be better served if you got the parts off of a car that has R134 on it.
When you find a car, check to see if the system still has a little gas. If it does, then you should be good to pull them off and put them in your car. When your done, you will need something to either pull a vacume on the system, or take it to a shop to have done.
The 87 Honda I added A/C to works great. The 89 is still waiting for me to get to putting it in.
Old 10-23-2007, 08:15 PM   #8
smccall's Avatar
ok, its great to know it can be done. Thanks for the input.
Old 10-23-2007, 10:12 PM   #9
Member
78si's Avatar
I did my 92 civic SI.. Honda makes it plug and play. Make sure you have all the parts!
78si is offline   Reply With Quote
Old 10-23-2007, 10:21 PM   #10
garyhgaryh's Avatar
I bought a vacuum pump at Harbor Freight to evac the system. I wonder how it works....
http://www.harborfreight.com/cpi/cta...temnumber=3952
Let the games begin! Matt Timion General Fuel Topics 4 12-12-2021 12:04 AM
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 11:54 PM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
Volvo 240 High-MPG project car wins employee car show brucepick General Fuel Topics 8 06-26-2007 09:59 AM
