Adding A/C to a non A/C VX?! - Page 2 - Fuelly Forums
Old 10-24-2007, 06:34 AM   #11
smccall's Avatar
Originally Posted by 78si View Post
I did my 92 civic SI.. Honda makes it plug and play. Make sure you have all the parts!
How long did it take you to do it?? I found an entire factory air kit for $560 plus shipping. Do you have any instructions on doing this?
Old 10-24-2007, 06:47 AM   #12
Member
78si's Avatar
It took an good afternoon. I dont have any "written" instructions, but I can answer your questions.
78si is offline   Reply With Quote
Old 10-24-2007, 07:03 AM   #13
smccall's Avatar
ok, I'll keep that in mine when the time comes, thx
Old 10-24-2007, 04:05 PM   #14
jadziasman's Avatar
Gary,
You need a really powerful air compressor to make the"air vac" work. You are better off to get a real vacuum pump to do the job.
Old 10-26-2007, 09:21 PM   #15
garyhgaryh's Avatar
Originally Posted by jadziasman View Post
Gary,
How many PSIs? I did research on this and in order for me to pull a decent vacuum, I need to do it when it's HOT.. like over 100deg. I forget the reasoning....
To the canadians: can you guys still get R12?
Gary
garyhgaryh is offline   Reply With Quote
Old 10-27-2007, 03:59 AM   #16
jadziasman's Avatar
At least 90 psi with at least 6 cubic feet per minute capacity. The air compressor will need to be fairly big (5 gallon or larger) to deliver a sustained blast of 90 psi.
Heed the advice of someone who has been where you're going. Forget the Air-Vac and get a small rotary vane vacuum pump.
The one I bought was a FJC model 6908. It is a single stage pump with 1.5 cubic feet per minute "suction". It does the job and only cost $99 plus shipping.
As to the ambient outside temperature "needed" to draw a deep vacuum. A strong vacuum can evaporate and pull out the water in the A/C lines regardless of the outside temp since the volume of air in the Civic system is relatively small (PV=nRT). Higher outside temperatures make it easier to draw a vacuum with a less powerful vacuum source (like that Venturi air vac you want to use). My FJC vacuum pump worked fine and it was only 50?F outside when I originally worked on mine in April 2006.
As I mentioned earlier, get the proper tool for the job and make it easier on yourself - especially since you have not done the job before. But as many have said YMMV.
Old 10-27-2007, 01:14 PM   #17
garyhgaryh's Avatar
I have a 20gallon tank. Yeah, I will look into the rotary vacuum pump.
Where can I get one at that price?
Thanks,
Gary
Old 10-27-2007, 04:22 PM   #18
jadziasman's Avatar
Just take the mfg & model # FJC 6908 and do a search on Google or yahoo. I bought this pump from an internet seller - not ebay as I recall anyway. You should be able to get one for no more than $125 still. Not many rental places carry these but you might get lucky find one to rent.
Old 11-03-2007, 02:57 AM   #19
Originally Posted by Gary Palmer View Post
You can use R134 in an R12 system, but you would be better served if you got the parts off of a car that has R134 on it.
Excellent point. You CAN use R134a in system designed for R12. But you will inevitably end up with a poorly performing A/C if you do. So if you DON'T want to deal with trying to obtain R12, it is best to find a system that was designed to use R134a.
As for retrofitting a Civic without A/C, I have found this to be quite an easy affair. From my experience, everything is pretty much plug-and-play when it comes to installing a FACTORY A/C on a car that did not come with A/C wen new. The same probably cannot be said about aftermarket units.
Old 11-03-2007, 08:17 AM   #20
mrmad's Avatar
I converted the Nissan I had and it was working fine when I sold it 2 years later. I converted the wife's 4runner at the same time and 4 years later the AC is still cold. Neither produced cold air as well as they were with R12, but they are cold enough.
Let the games begin! Matt Timion General Fuel Topics 4 12-11-2021 11:04 PM
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 03:13 AM
Volvo 240 High-MPG project car wins employee car show brucepick General Fuel Topics 8 06-26-2007 08:59 AM
