A couple VX questions - Fuelly Forums
Old 07-01-2008, 06:30 PM   #1
I have a 1992 VX California emissions. As some of you may be aware, all '92s came with the 5-wire sensor. The Cali. car just had a different ECU that didn't implement lean burn. I bought a Federal ecu to switch on lean burn.
Well, mine is throwing a code 48 (lean fuel sensor). I called by local import parts supplier and they want $550 for the 5-wire sensor. I knew they were pricey, but I thought $200-300, not $550!
So now I'm considering swapping to a 4-wire sensor and using the Cali. ecu.
2 questions:
1. Does anyone have a source for cheaper 5-wire sensors?
2. Can anyone help me with the 4-wire conversion? I know this is backwards from the way most people around here convert a VX.
GasSavers_Crazy88 is offline   Reply With Quote
Old 07-01-2008, 07:09 PM   #2
2 questions:
this might do it
http://cgi.ebay.com/ebaymotors/ws/eB...EF:MOTORS:1123
mini-e is offline   Reply With Quote
Old 07-01-2008, 08:25 PM   #3
Especially since you already have the Federal ECU, I think you're making a mistake to switch back to 4-wire. If your VX is in decent shape, it should maintain good resale value (unless gas suddenly gets ultracheap hahaha), and it will be worth more to the next owner with the right sensor. And it will also save you gas, in the meantime.
I would look for the L1H1. I suppose the L2H2 will work, but I think you will have to put some extra effort into wiring the connector (instead of just plugging it in).
If you look around, you should be able to find the L1H1 for $150-200. Maybe less.
Here's one on eBay right now for $177, shipped:
http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWD1V
Old 07-01-2008, 08:27 PM   #4
Thanks! Have you used one of these before?
Old 07-01-2008, 08:27 PM   #5
GasSavers_Binary's Avatar
Here's another.. a little more pricey than that one mini-e found, but a member on another forum I'm on purchased one for his VX to CRX spaw and it worked out great for him... personally I'd go with the one in the other post because I'm cheap like that, but here's just another option.
http://cgi.ebay.com/ebaymotors/HONDA...3286.m20.l1116
Edit: Ha! looks like I was too late
Big oil execs making 32mil a year and we're paying upwards of $4 a gallon.. Hubberts peak you say? Oh ok, I believe you.
GasSavers_Binary is offline   Reply With Quote
Old 07-01-2008, 08:33 PM   #6
We posted two minutes apart. What's the old expression? Great minds think alike.
I agree that the cheap one is tempting. I'm just not totally convinced that the L1H1 and the L2H2 are really perfectly interchangeable.
Old 07-02-2008, 09:28 PM   #7
Reborn996's Avatar
Send a message via Yahoo to Reborn996
I bought the one Monroe listed ($177 shipped) for my 92 CA version VX which was fitted with a Federal ECU. Runs great, no CEL, and just passed CA smog with flying colors. It works!
David
2005 Honda Civic Hybrid - commuter
1999 Porsche 911 C2 - weekend toy
2005 Toyota Tacoma - hauler/work truck
Reborn996 is offline   Reply With Quote
Old 07-03-2008, 01:49 AM   #8
garyhgaryh's Avatar
2 questions:
I just posted this a minute ago in another thread. I bought a genuine Honda L1H1 from a guy on ebay for $150. They're expensive from the factory. Apparently he bought it years ago and never used it.
I have a CA VX. I'm going to do the ca-fed conversion. I got the ecu and now the l1h1 sensor. Where in CA are you? perhaps we can get together to do this conversion together.
Gary
garyhgaryh is offline   Reply With Quote
Old 07-03-2008, 06:19 AM   #9
Hi Gary, welcome back. I think you were away from the forum for a while.
A while back (http://www.gassavers.org/showpost.ph...5&postcount=40) I tried to answer some of your questions. So I would be glad to continue to do that (in that thread or this one), if you need some help.
Carbon fouled O2 Sensor:'92 VX - Perplexed Darkelf General Maintenance and Repair 15 03-17-2008 09:16 PM
old user, new car kamesama980 Introduce Yourself - New member Welcome 0 02-28-2008 06:58 PM
100 MPG Pruis - Australian Silicon Chip mag. GasSavers_Pete Automotive News, Articles and Products 0 02-12-2008 06:53 PM
Better gas mileage for an RV 73challenger General Fuel Topics 5 10-31-2007 05:08 AM
