94 VX Spare, can you mount a 165/70/13 tire on it? - Fuelly Forums
Old 07-16-2008, 03:56 PM   #1
My little donut is a 105/80/13, will a stock size 165/70/13 tire fit on this little rim or is it too narrow? I am ordering tires this week, thought I'd throw another one in if it will fit in the back hatch under the floor.
-J
jshelton441 is offline   Reply With Quote
Old 07-19-2008, 01:21 PM   #2
GasSavers_JoeBob's Avatar
-J
I may be wrong on this, but I don't believe those rims are designed to have the tires replaced.
Old 07-19-2008, 06:23 PM   #3
gork57's Avatar
Suggest getting a used stamped steel 13x5 Honda wheel to use for a spare if you must (standard VX alloys are 13x5). I sincerely doubt the spare rim will hold a full size tire. In addition, the extra weight of a full size tire and rim will most likely have a negative effect on your fuel economy. Experience has taught me that what seem to be minor things can have a relatively large impact on VX mileage.
Simplicity is the glory of expression.-Walt Whitman
gork57 is offline   Reply With Quote
Beating the Baro... MAP reading trickery? GasSavers_RoadWarrior General Fuel Topics 4 03-06-2008 02:43 AM
Performance Underdrive Pulleys? cfg83 General Maintenance and Repair 10 09-08-2007 09:04 PM
When you pull over... VetteOwner General Discussion (Off-Topic) 12 04-06-2007 10:52 AM
