92 VX water leak - Fuelly Forums
Old 03-17-2013, 11:48 AM   #1
92 VX water leak
My 1992 VX has a leak that appears to be behind the dash. The passenger side floor gets soaked when the car sits in the rain. Spoke with a former Honda tech and he said it will require a lot of work to get at it. All day job. Is there any other way? Foam sealant in a certain area? Any help would be appreciated.
wilco58 is offline   Reply With Quote
Old 03-18-2013, 04:03 PM   #2
There was a longexpired tsb about it the seal between the body panels has lost it's sealant. Better fix it before it takes out the ecu.
Rusty94cx is offline   Reply With Quote
Old 03-18-2013, 05:55 PM   #3
Here.
92-95 passenger floor all wet after rain? heres directions on how to fix. - Honda-Tech
Old 03-19-2013, 06:10 AM   #4
Thanks
Thanks Rusty
Old 03-19-2013, 10:15 AM   #5
GasSavers_WD40's Avatar
Thanks Rusty great link, my vx has been leaking like crazy on the drivers side for years, now I know what to do to fix it
GasSavers_WD40 is offline   Reply With Quote
Old 04-02-2013, 06:20 PM   #6
A few years ago they would fix it for free sorry.
Old 04-04-2013, 10:34 AM   #7
slogfilet's Avatar
I have the same issue with the cargo area getting wet... not quite sure how to track it down.
slogfilet is offline   Reply With Quote
Old 04-04-2013, 04:30 PM   #8
That leak is the tail light gaskets being bad. Same problem here they are like 5-10$ dollars each. They are just a rubber gasket. Still available.
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
VX catalytic converter replacement slogfilet General Maintenance and Repair 9 11-22-2010 03:15 PM
How to FE drive when OAT is hot? GasSavers_rGS Hypermiling 3 07-19-2007 03:35 PM
