92 VX speedo stopped working - Fuelly Forums
Old 06-01-2013, 09:19 AM   #1
Ok
The speedo stopped but the odometer is still working, It started just jumping around.....then it went all the way around to past 120 to the peg on the back side of zero....
Speed sensor ?
Why is odometer still working if the speed sensor is bad ?
Thanks in advance
Coconut Sunrise is offline   Reply With Quote
Old 06-02-2013, 06:31 AM   #2
It's the speedo head it's self. Junkyard or try to resolder all the joints.
Rusty94cx is offline   Reply With Quote
Old 06-02-2013, 10:15 AM   #3
ukrkoz's Avatar
the speedometer handle came off the pin. Happens too. Pull cluster out, remove plastic cover, and make sure it's not loose. A dab of Loktite on it will fix this.
Sometimes they run speed off distributor, as per tachometer, but I doubt you have that.
ukrkoz is offline   Reply With Quote
Updating Gaslog Graphs? Kohote Fuelly Web Support and Community News 11 07-15-2013 07:01 PM
Are you guys doing alright? axehead Introduce Yourself - New member Welcome 24 01-16-2013 06:53 AM
2012 Mayan Apocolypse Jay2TheRescue General Discussion (Off-Topic) 3 12-23-2012 06:35 PM
The Eclipse at Shatto's Home May 20, 2012 shatto General Discussion (Off-Topic) 0 05-20-2012 11:44 PM
