92 accord starting problem - Fuelly Forums
Old 02-11-2008, 05:04 AM   #1
My friend has a 92 accord lx with the 2.2, and it is having trouble starting. It has trouble starting both hot and cold. It can only be started when starting fluid is sprayed in the intake, and once running runs fine. Any ideas?
Do you think it is an ECU problem? I told him to go thru all of the ignition items, like cap rotor plugs wires. it seems like since it runs fine once it is going, it is getting fuel. Could be dirty injectors, but i think the problem started all of a sudden. maybe a failing coil?
GasSavers_James is offline   Reply With Quote
Old 02-11-2008, 08:44 AM   #2
101mpg's Avatar
Check cap, rotor for spark when starting.
Have any auto parts store check your coil for free - unless you know how to use your own multimeter, which takes nearly no time.
Change your fuel filter - this is just OH so cheap.
Could also be the main relay (I have been advised of this for many starting issues on Hondas).
Seafoam (there are threads on this - a great cleaner (which should help clean injectors if you use the 1/3, 1/3, 1/3 mixture in low gas in tank, oil and intake)) - will require an oil change if you use the above method.
The above checks and replacements should be under $20 except for replacing cap, rotor or coil if any are bad.
Barring this - could be a failing fuel pump?
Old 02-11-2008, 09:15 AM   #3
Danronian's Avatar
Sounds to me like the main relay or a clogged fuel filter.
GL on the fix.
Download a shop manual if you don't have one already. Search the net for one, they can be easily found for any Honda.
Old 02-11-2008, 04:11 PM   #4
thanks for the advise. unfortunately, I can't work on the car since it is in FLA and I am in NY. So I will relay the info to him and see if he can fix it. I figure he might as well change the fuel filter first, and then check the main relay.
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 11:54 AM
Car trouble woes Fourthbean General Maintenance and Repair 10 07-30-2007 04:54 AM
Mazda3 S Touring psyshack Introduce Yourself - New member Welcome 12 07-17-2007 08:34 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
New to GS - proudly got 38mpg in my 90 corolla today! aelfwyne Introduce Yourself - New member Welcome 9 09-25-2006 11:47 AM
