91 crx hf repair - Fuelly Forums
Old 02-07-2011, 04:29 AM   #1
91 crx hf repair
Hello,
I need to replace the egr valve in my stock 91 crx hf. Is this relatively easy? How is it done?
Any advice would be greatly appreciated!
Ben
Benwallen is offline   Reply With Quote
Old 02-25-2011, 08:04 PM   #2
mrmad's Avatar
Re: 91 crx hf repair
Changing the EGR valve is easy, it is just a few bolts. One problem I had on my HF was the tunnels in the IM were clogged with carbon. I managed to get this cleaned up with tiny shots of carb cleaner. If you apply vacuum to the EGR hose while the car is idling you should be able to see the diaphragm move and it should kill the engine at idle. If the diaphragm moves and the engine doesn't die, you probably have a clogged IM.
Filter by Imperial vs. U.S. Gallons? bvz2000 Fuelly Web Support and Community News 4 05-02-2013 08:33 PM
new comer to jdm civicricerx Introduce Yourself - New member Welcome 1 06-12-2010 04:54 PM
an increase of 20mpg cost me... chesspirate General Discussion (Off-Topic) 31 01-22-2008 04:22 AM
