89 CRX timing belt replacement interval?.. - Fuelly Forums
Old 11-15-2020, 09:29 PM   #1
Hello,
Has anyone seen the same maintenance schedule for timing belt changes on the CRX? I used to own a '91HF, and found a 90K timing belt interval...but for this same engine on 88 & 89 cars I only found a vague mention of inspecting the belt to determine when. As we all know, inspecting a T-belt doesn't always tell the story. I see no reason why this same engine with the same timing belt (assuming it is the same timing belt) shouldn't also be 90K intervals.
thanks
alexsunny
alexsunny123 is offline   Reply With Quote
Old 11-16-2020, 07:26 PM   #2
90k to 110k are intervals I've heard for other makes and models. My family's 2000's Hondas and Acuras had 100k intervals.
Old 11-19-2020, 07:10 PM   #3
Originally Posted by alexsunny123 View Post
Hello,
Has anyone seen the same maintenance schedule for timing belt changes on the CRX? I used to own a '91HF, and found a 90K timing belt interval...but for this same engine on 88 & 89 cars I only found a vague mention of inspecting the https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam belt to determine when. As we all know, inspecting a T-belt doesn't always tell the story. I see no reason why this same engine with the same timing belt (assuming it is the same timing belt) shouldn't also be 90K intervals.
thanks
alexsunny
thanks my issue has been fixed.
