88 CRX 97 Integra LS Cluster, what VSS do I need? - Fuelly Forums
Old 04-01-2007, 08:03 PM   #1
UfoTofU's Avatar
I was under the impression that I needed a 92-00 Civic VSS and that any one would work.
Today I picked up what I was told was a 93 Civic VSS. Unfortunately this unit won't fit without pretty major modifications that I am not real sure if I want to do or not.
I'm wondering if this one doesn't fit because I have an auto tranny and this is made for a stick? I also read that a 96-00 Civic VSS should fit without any problems as it is less bulky
I started a thread on honda-tech that has some pictures.
http://www.honda-tech.com/zerothread/1940454
Do I have the right VSS or do I need another one?
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 04-01-2007, 08:09 PM   #2
Oh ****, I forgot to answer you.
This is the VSS I used. Luckily I dropped the tranny with the vss in it and broke it in half and broke off the mounting tabs as well. This allowed it to fit just perfectly,
You need to cut off the mounting arms and just stick it on in there.
Also, to get the old one out, leave the PB blaster sitting for a night, try using a huge wrench to wiggle it back and forth, and failing that, cut a deep notch in the outer edge of the vss and use a hammer and big screwdriver to hit the notch back and forth to try and wiggle the vss out.
Old 04-01-2007, 08:12 PM   #3
UfoTofU's Avatar
So the pictures I have posted on H-T are of a unit that will work but I just need to hack off some pieces?
In the pictures do I cut off all the parts but leave the highlighted box#2 piece on? That seems to be how the unit will mount back to the tranny.
- UfoTofU
Old 04-01-2007, 08:14 PM   #4
Hmm, you have a different but similar vss from me. But it looks like you can cut one and two if that's what you need. Get the old vss out and take a picture with them together,
Old 04-01-2007, 08:18 PM   #5
UfoTofU's Avatar
I will do that tomorrow morning. Hopefully the PB Blaster that I am letting soak over night will let me pull it right out tomorrow.
- UfoTofU
Can a fillup be edited? djlen Fuelly Web Support and Community News 2 12-22-2011 11:11 PM
Greetings kps Introduce Yourself - New member Welcome 10 09-26-2006 06:15 PM
E-85 and EPA rating zpiloto General Discussion (Off-Topic) 7 09-26-2006 07:04 AM
1995+ Metro Front Brakes 95metro Experiments, Modifications and DIY 15 07-04-2006 03:12 PM
