88 Civic D15z1 Swap, Getting Engine Code 16 What could it be? - Fuelly Forums
Old 10-25-2006, 03:25 PM   #1
So i swapped a d15z1 in my 88 civic sedan. I managed to convert it to mpfi, got most of the bugs worked out and finally was able to get the car started to where it stays on. I keep getting engine Code 16, which means its a fuel injector problem. I ran through the diagnostic check in the 92-92 honda civic manual (same as 88-91 civic manual except no resistor box is needed and resistance is different) and i get to the last part where it asks me to try a different ecu. I have a P07 which corresponds to that engine, and i substituted the edu with a P13 (OBD1 Prelude, which i know works fine) and the car starts as ussual but i still get Code 16. Now i know that it might be related to the fuel pressure and the main relay.
I re-soldered the relay, but it showed signs of having been repaired in the past. this didnt fix the problem.
The only thing i can think of now is the fact that i have not changed the fuel filter and that i used the 88 civic fuel line, i just twisted it so that it would fit correctly, Could the fact that i didnt use the VX engine fuel line cause this problem? Ive been meaning to get a fuel pressure tester but im not sure what to look for when purchasing one.
has anyone had this problem, or know how i might be able to fix it?
Thank you in advanced.
8Civic8 is offline   Reply With Quote
Old 10-25-2006, 03:50 PM   #2
FormulaTwo's Avatar
Send a message via AIM to FormulaTwo
i would check your wiring to the fuel injectors
i guess it could be the injectors themselves
Order some golf shoes, otherwise we might never make it out of this place alive.
FormulaTwo is offline   Reply With Quote
Old 10-25-2006, 03:53 PM   #3
Well, i went through the diagnostic and i get voltage both at the injectors and at the ecu. But for some reason i still get code 16.
Old 10-25-2006, 03:58 PM   #4
Matt Timion's Avatar
I got that code once before too, and it was solved by resetting the ECU.
The main relay might be a culprit,, as might the injectors. I'd recommend cleaning them individually and seeing what happens.
Old 10-25-2006, 04:04 PM   #5
How do i go about cleaning the injectors? Also, if i where to buy a noid light to check for signal which one would i buy? Would it be the one for the bosch plug style?
Old 11-02-2006, 05:26 PM   #6
GasSavers_TomO's Avatar
What injectors are you using? The stock VX ones or ones from another honda?
Honda Civic VX Info/Links
Old 11-02-2006, 06:44 PM   #7
I supposedly bought a jdm d15z1 and i am using everything that was on it. Although the injector plugs appear to be from a obd2 engine. The engine looks exactly like the one below except not as oxidized.
As you can see, that engine (which is just like my engine) has obd2 plugs. Would it cause a problem if i am using obd2 injectors with obd1 ecu? Could that cause error code 16?
As i come to find out, honda also made a d15z (not d15z1), i am not sure if that was also called vtec-e but it was an obd2 engine (present on 96 and newer engines only). Its hard to tell because they were all stamped d15b. If this is so, it means my engine has 130 hp and not 92, defeating the purpose of swapping my engine because i wont get the fe i wanted.... Anyone has any insight in this matter?
Old 11-02-2006, 10:28 PM   #8
Beats me , but maybe this helps.
Old 11-03-2006, 01:04 AM   #9
I managed to convert it to mpfi,.
You converted a single throttle body injection to multipoint EFI without a computer change ? ? ?
Old 11-03-2006, 10:29 AM   #10
No, i did change the computer. I am using a P07 as i stated in my opening comments.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 09:10 PM
Car stalls when idling and A/C is on Matt Timion General Maintenance and Repair 7 05-20-2006 03:32 AM
New Camry Hybrid... cool display! Matt Timion Hybrid Vehicles 6 01-19-2006 04:29 PM
