I think I posted about this car earlier asking about it's estimated mpg... but new topic:
It's got the SOHC B6 Mazda 1.6L in it, engine was working but then started stumbling (previous owner) and I found water in the oil, and air bubbling out of the radiator under pressure. This with a cold engine.
I pulled the cylinder head, and the most of the non-metallic bits of the gasket are stuck to the block and head (haven't scraped yet), but I dont see where there was an obvious leak. No discoloration around the bores, and no obvious leaks between oil and water passages either. I CAN tell however the head has been off before. It was missing a washer on a head bolt, and the exhaust wasn't rusted on. Some of the exhaust and intake bolts were replaced with studs, I dont think that's stock. Exhaust gasket looked good, intake gasket got bits stuck to the manifold and head.
So far I have 50 cents invested in this car. It's got ~180k miles, the cylinder walls look pristine, and it's got a 5 speed (good hypermiler?
The headgasket set is $60. I'll need a timing belt too now. Should I put a gasket in and hope it fixes it, with the risk of the head being cracked instead? Any ideas what it costs to get a head pressure tested so I can be sure? I could probably find a used head cheap enough if I can get it tested cheaply...
