Originally Posted by panamacolin
I ordered mine from Global-Automotive...purchased off of ebay...the o2 sensor did not work. When I installed it the CEL came on and it would not turn off. I reset the ECU and nada check engine light...high idle..and eratic. Just got refunded for the part....not a fun procedure. I def. dont think it was the right part.
I would not order the part off ebay...especially from Global-Automotive. They were rude in the repsonse letter and I almost did not get a refund. I had to call my visa credit card to get them to contact global auto for me...otherwise I would have been stuck with a bogus part...
best of luck to everyone...if you find another cheap part that is legit I would be interested to know.
Colin, I'm also having a CEL light! No more stutter, car is running buttery smooth now, but high idle (idle was high before as, well tho, and mechanic thinks high idle may be due to a faulty ECU) and the CEL is now on.
Anyway, should I not drive it with the CEL on? My old o2 sensor had the wires cut to remove it (damn mechanic cut the wires without warning) so I can't exactly reinstall the old one.
three
stripes the charm!
