$79 5 wire O2 sensor - who has bought one? - Page 8 - Fuelly Forums
Old 10-24-2007, 03:47 PM   #71
1993CivicVX's Avatar
Heh, cool. So it's the Lean Air Fuel Sensor. Is that part of the o2 sensor?
three stripes the charm!
Old 10-24-2007, 03:48 PM   #72
jadziasman's Avatar
Would someone please tell our less experienced 'savers to use the pdf helm manual! Okay I guess I will. The manual shows everything and is pretty good at instructing how to check codes with the service port off the ECU. SVOboy has a amateur mechanic's wisdom well beyond his chronological age.
All you need to do is google "honda civic helm pdf" and go down the list to the General Tech Help hit. Download and you've hit pay dirt. It works today so don't delay and download it!
Anyone who tries to repair a Honda without the helm manual deserves the trouble he got himself into. Hell, it's hard enough even when you've got one!
Old 10-24-2007, 03:49 PM   #73
Oh yeah, I should've mentioned the helms...sometimes I feel like I know too much for 19, but then I realize I know less than I did when I was 17,
Anyway, IM me if you want jace, I'm cruisur on aim.
Old 10-24-2007, 04:20 PM   #74
Does anyone else want to corroborate on SVOboy's finding? TomO? What do you think?
Old 10-24-2007, 04:30 PM   #75
Dude: You are being belligerent, stupid and ignorant. You want to pay your mechanic to fix the car, but want to beef, go beef at him. As far as experience, education or anything else goes, I believe I am as good as any mechanic you can find, only with a whole lot more education. Before you go blasting the folks that were trying to help you, you ought to consider the possibility that they might know a whole lot more than you think. The guidance you were given was solid, sound and based upon your information. Garbage in, garbage out. You wanted help, you got help. That help was not based on wild armchair whoopela, it was based on some hard core, hard learned experience.
Your pissed cause your mechanic did exactly what you were told to do, tough go find some other place to...
Old 10-24-2007, 04:32 PM   #76
Originally Posted by TomO View Post
MY predictions:
  • You are throwing a code 42
  • You will dump your mechanic
  • The CEL being on is what is causing your non-hesitation issue (it's ignoring the O2 sensor now and running open loop all the time, decreasing your gas mileage)
  • You will go out and buy a metric socket and wrench set for cheap
  • You will be able to work on your own car through our help
  • You will be able to save a sh*t-ton of money doing it all yourself
  • The high idle is either a messed with idle screw or vacuum leak, trust me!
Once you get the CEL taken care of (either get your mechanic to re-install the old one once he SOLDERS the old wires back on the old sensor or buy you a new one from Honda), turn the idle screw clockwise until it is snug (once the car is warmed up). Then turn it counterclockwise until your tach is reading about 600RPM without the climate control fan, A/C, radio, lights or anything else on in the car.
I did buy a socket set. It's a bunch of metric sockets with an extender. I'm ready to work! heh. I want to uninstall my ECU and install the new one. I can use my socket set for that?
Old 10-24-2007, 04:44 PM   #77
garyhgaryh's Avatar
Originally Posted by 1993CivicVX View Post
Can I do any damage if that isn't correct?
The plugs can only go in one way and in the specific connector.
So, I doubt you can damage it esp if you're careful. Just to be
paranoid, ground yourself....
Gary
garyhgaryh is offline   Reply With Quote
Old 10-24-2007, 04:46 PM   #78
garyhgaryh's Avatar
First thing I do is I turn the key to the on position, right?
I then take a metal paper clip right? Does it have to be metal or will an insulated one work? I bend it to make a U shape? I stick the two ends into either hole in that blue thingmajig?
Correct?
I then take my video camera and film the flashing lights and tell you guys what they did. And let you guys decipher. Thanks.
I use a paperclip.
Old 10-24-2007, 04:57 PM   #79
Originally Posted by dogncatboy
Have you reset the ecu (do this after checking for codes)? Just pull the fuse to it for 10 seconds or so and replace. Good luck.
How do I locate that fuse? Thanks.
Old 10-24-2007, 05:00 PM   #80
It's in the fusebox under the hood, look around til you see something that looks like a fusebox, should be on a shock tower.
Also, you can just disconnect the battery.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Synthetic Bad for the TSX rh77 General Fuel Topics 41 11-30-2006 12:02 PM
Hello GasSavers_scostanz Introduce Yourself - New member Welcome 7 06-25-2006 07:37 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
