$79 5 wire O2 sensor - who has bought one? - Page 2 - Fuelly Forums
Old 10-19-2007, 03:48 AM   #11
1993CivicVX's Avatar
Originally Posted by dogncatboy View Post
Here is a link to the one I just installed.
http://cgi.ebay.com/ebaymotors/ws/eB...173410075&rd=1
It seems to work just fine. My car had the O2 sensor code prior to installing and has since not thrown any codes. If it is important, I can check the color of the wires for you after the sun comes up.
It would be very helpful in light of what several people have said about the blue wire.
my wires are blue, yellow, gray, white and black.
Thanks!
three stripes the charm!
Old 10-19-2007, 06:06 AM   #12
Junior Mint
dogncatboy's Avatar
I also have blue, yellow, white, gray and black wires. I don't have a CEL on and no codes. I did have a O2 code prior to swapping it out, none now. Car just came back from mechanic and it seems to all check out OK. I've put over 1000 miles on the new sensor with no ill effects so far and the best mileage to date, 46mpg last tank with timing belt off 1 tooth.
... D'oh!
dogncatboy is offline   Reply With Quote
Old 10-19-2007, 06:11 AM   #13
Junior Mint
dogncatboy's Avatar
I just found this online, don't know if its true:
NTK L1H1/L2H2:
The L1H1 sensor was originally used by Honda in their 92-95 Honda Civic 3 Door, 1.5 VTEC OEM Part# (36531-P07-003). The L2H2 sensor is NTK's new sensor revision, higher quality, more rugged design and is 100% compatible with the L1H1. These two sensors are fully compatible with the M-200 controller.
Original post is HERE
BTW, the post says that the Bosch sensors work too... D'oh!
I also found this which seems to confirm the above:
The L1H1, L2H2 & NTK-VW sensors are NTK/Honda UEGO wideband pump cell sensors. The name UEGO is traditionally associated with this range of sensors, and stands for Universal Exhaust Gas Oxygen. They were co-developed by Honda & NTK (the speciality ceramics division of NGK) and first appeared in the early 1990s on Honda 1.5 Litre engines. There's some more information relating to the older Tech Edge 1.5 unit and the L1H1. They predate the Bosch LSU sensor but, apart from the higher price Honda seems to want to maintain, are still good sensors. The L2H2 is the updated L1H1 and neither are sold by Tech Edge. Just to confuse you, Bosch source the L1H1 sensor from NTK and package it as their 13246 sensor.
This info comes from HERE
... D'oh!
Old 10-19-2007, 10:50 AM   #14
Cool, man, thanks. Maybe I put it in this weekend!
I have a question for you. If you were to accelerate slowly from low RPM, particularly in gear 1, 2 or 3, would your car stutter, lurch, stumble, hesitate or anything like that? My car is still doing that. Did it ever do this with you? Did you notice any difference in how the car drives since you put in the new o2 sensor?
Old 10-19-2007, 12:36 PM   #15
Junior Mint
dogncatboy's Avatar
Yeah, I had issues like that. I changed my O2 sensor and plugs at the same time, so its hard telling if it was the actual culprit tho.
... D'oh!
Old 10-19-2007, 04:25 PM   #16
AlainB7's Avatar
http://www.gassavers.org/showpost.ph...2&postcount=16
Here is the one I order from Global Technomitive on e-bay, and it work great. My FE is incredibly better. No CEL and no problem.
It as the NTK stamp on it and 36531-P07-003 sticker on top.
92 Mitsubishi Galant VR-4 4G63 A/T AWDTturbo 12.122@112.9 mph 0-60MPH:3.6s 50-75MPH:2.4s ,2x 92 Honda Civic VX (4.7l/100km)
Gone in 12 seconds GO FAST WITH CLASS, DON'T USE NOS!
AlainB7 is offline   Reply With Quote
Old 10-19-2007, 08:02 PM   #17
right plugs helped my car a lot but did not solve the problem completely. So you don't have those issues anymore?
Old 10-19-2007, 08:09 PM   #18
Here is what mine looks like:
NTK JAPAN engraved in the metal and right below that it has a blue band that has the following written on it.
HONDA 36531-P07-003
Yay
Old 10-19-2007, 11:16 PM   #19
garyhgaryh's Avatar
HONDA 36531-P07-003
Yay
Is that the new $79 O2 sensor you're talking about or the one that is on your car now?
Gary
garyhgaryh is offline   Reply With Quote
Old 10-20-2007, 06:31 AM   #20
that would be the new $79 one I bought.
But good point, I will compare it to the old one.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Synthetic Bad for the TSX rh77 General Fuel Topics 41 11-30-2006 12:02 PM
Hello GasSavers_scostanz Introduce Yourself - New member Welcome 7 06-25-2006 07:37 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
