$79 5 wire O2 sensor - who has bought one? - Page 17 - Fuelly Forums
Old 10-26-2007, 07:23 PM   #161
GasSavers_TomO's Avatar
Originally Posted by 1993CivicVX View Post
Wow, paint job looks pretty pro.
I agree with jacinto on the paint Job. It looks great and a great looking color, Gary.
TomO Based on your hypothesis, does that mean my o2 sensor is working properly once it is warmed up and the only thing wrong with it is that it's taking too long to warm up?
That is what I'm inferring from the information you gave us on the condition that is causing the CEL to come on. Even though the CEL code for the O2 heater isn't being tripped. But remember YMMV (your mileage may vary) in other words...it may be something else that is causing your new O2 to trip the CEL.
Honda Civic VX Info/Links
Old 10-26-2007, 08:33 PM   #162
garyhgaryh's Avatar
Thanks Jacinto and Tom! The best part is, I used a $30 spray gun from the flea market. My friend Jaime and I bought each bought a gun at the market - my paint job came out better for some reason and yes, if you look at it close up, it's still glassy smooth (alot of dry sanding - that's the new wet sanding with just 3M discs).
Gary
garyhgaryh is offline   Reply With Quote
Old 10-27-2007, 04:09 AM   #163
1993CivicVX's Avatar
It may have been giving two codes TomO. After it finished giving the code, it started flashing again. I can't remember if I let it go all the way through again or if I just assumed it had started over. Seems plausible it may have been giving a second code. I didn't think to check for two codes at the time. But speaking of YMMV. It appears at this point my car is using less gas than it was before I popped the new o2 sensor in. Yeah, I'm duly impressed Gary. For a pro to do that would have cost you thousands of dollars!
three stripes the charm!
Old 10-27-2007, 11:26 AM   #164
from the good folks at Global-Automotive:
Dear Valued Customer,
If the light goes off once the engine is hot, then the sensor is not the problem.
There is probably another dead sensor by the cat conv.
If your mechanic was unable to properly diagnose this then we suggest you take it somewhere else.
Buyer cannot automatically assume the new item is defective, especially if the vehicle was never hooked to a scanner.
The plugs also need to be cleaned and inspected to assure proper contact. There are many things that could be the culprite.
We have been sell these 5 wire sensors for over 10 years to hundreds of smog and emission shops with no problems or returns.
Thanks,
Management
I find the last statement particularly interesting... no problems or returns.
the mechanic did have the o2 sensor hooked up to a scanner, but all he was able to tell me is that the o2 sensor is throwing the code -- and therefor needed to be replaced. What does anyone think of the parts I highlighted?
Old 10-27-2007, 11:38 AM   #165
I doubt they understand you have only one o2 sensor, I doubt the plugs would cause a problem, but whatever...you shouldn't have told them any conjectures about it stopping when getting warm, just giving them ammunition to decide not to give you a replacement.
Old 10-27-2007, 11:43 AM   #166
true, I guess I don't want to replace it and am hoping I can get it working without needing to replace it.
The guy at the junkyard actually said it could be the connectors as well. But, yeah, I'm inclined to agree with you that that doesn't seem likely. They weren't causing a problem for the last o2 sensor.
Old 10-27-2007, 12:38 PM   #167
GasSavers_bobski's Avatar
Originally Posted by Danronian View Post
From the two motors I have, I've never seen a FITV on a d15z1.
Good point. ^_^
Stuck PCV valve maybe?
Old 10-28-2007, 07:45 PM   #168
panamacolin's Avatar
I Hate Global Auto!
panamacolin is offline   Reply With Quote
Old 11-03-2007, 01:26 PM   #169
garyhgaryh's Avatar
Jacinto --
How's that O2 sensor working out?
I noticed your last fill up was 57mpg!
Gary
Old 11-04-2007, 05:45 PM   #170
bugsih's Avatar
FYI I just put one of these $79 o2 sensors in a 96 HX and I have drove it 100 miles and it seems fine. I removed the P07 sticker that was on the sensor and it says VW Audi underneath, Nice huh? Well at least its working, the wires are also a little shorter than the stock L1h1
bugsih is offline   Reply With Quote
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Synthetic Bad for the TSX rh77 General Fuel Topics 41 11-30-2006 12:02 PM
Hello GasSavers_scostanz Introduce Yourself - New member Welcome 7 06-25-2006 07:37 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
