-7 psi at idle? - Fuelly Forums
Old 11-08-2008, 05:02 AM   #1
-7 psi at idle?
I just got my boost vac gauge installed in the car, and I noticed that I was getting -7 psi for idle. That is about 14.25 inches of mercury, and I was wondering if this was normal, of if I need to be checking for leaks.
Old 11-08-2008, 05:50 AM   #2
GasSavers_Erik's Avatar
That's a little low, it should be 18-20" of mercury. Is that at a hot idle- such as 7-800rpms?
Wait, I see that your car is only 600cc- is it a 2 cylinder? If so, maybe 14" is acceptable.
Old 11-08-2008, 06:02 AM   #3
it's a 650cc 4 cylinder turbo. it's about the same at warm idle
Old 11-08-2008, 06:06 AM   #4
Is it idling smooth? Ignition timing that is retarded can cause low vacuum at idle. Or maybe your boost gauge's needle isn't calibrated correctly with the numbers on the dial.
Old 11-08-2008, 12:41 PM   #5
My '88 Escort holds about 20-21 inches vacuum at idle hot or cold.
Hipermiler
#47 on my way to #1
Old 11-08-2008, 02:04 PM   #6
kamesama980's Avatar
that's pretty low for idle. things like vacuum don't change much for engine size. briefly I thought it might be the turbo but it shouldn't be doing anyhting at idle. I'd start by checking for vacuum leaks and that the throttle plate is closing fully.
-Russell
Old 11-08-2008, 04:08 PM   #7
Try reving it up and see if the vacuum increases. An engine that small doesn't generate a lot of vacuum at idle because of all the losses moving four small pistons but reving it up should make a little more vacuum.
Old 11-09-2008, 01:45 AM   #8
vacuum increasedto -9 psi, and goes to -10 on a hill.
Old 11-09-2008, 08:35 PM   #9
suspendedhatch's Avatar
Is it a cheap brand of gauge? Find something you can check it against. Like a vacuum diagnostic tool.
Old 11-10-2008, 08:43 AM   #10
Not sure if that is correct because usually vacuum is measured in inches of mercury except in Turbo gauges.
for the inches of vacuum multiply by 2.0293855020699732121113726763536
so 10spi is about 20.2 inches of vacuum sounds about right.
500mm vacuum = 9.7 psi
Atmospheric pressure is about 15psi and that is about 30-32 inches of mercury about 2 to 1
Ruses to stop tailgaiters ArtFox General Fuel Topics 41 06-16-2008 05:52 AM
Am I calculating this right? stumeston General Fuel Topics 8 12-15-2007 08:56 AM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
Hello everyone cubajean10 Introduce Yourself - New member Welcome 7 09-12-2007 10:13 AM
Make the page lengths 30 posts again, please SVOboy Fuelly Web Support and Community News 4 05-18-2006 01:43 PM
