![Reply](https://www.fuelly.com/forums/images/fuelly/buttons/reply.gif) |
11-29-2007, 07:35 PM
#1
is this a d15z1?? (JDM d15b)
just got this in the mail today (yipee!)...but I hesitated when I saw this on the block:
"HM
D15B
7603434
1
95"
I was told that this was one of those JDM imported engines and was a d15z1... just wanting confirmation that this is the real deal!
Here's a pics of the engine (it looks to be the correct valve cover and exhaust manifold...so I'm assuming it's the d15z1)
from post #4 in ( http://www.gassavers.org/showthread.php?t=5770) :
Originally Posted by Matt Timion
once again, there are three JDM d15b engines.
There is one that is the EXACT same as the d15z1
There is one that is a normal Vtec engine like the d16z6
and there is one that is the is three-stage vtec engine, offering the best of both worlds.
thanks for any help!!
11-29-2007, 08:12 PM
#2
Looks like it from this pic.
Take a pic of the vtec solenoid (near the EGR valve mounted to the head). If it only has one solenoid, it's vtec-e. Also checking to see if it has roller rockers will tell you if it's the vtec-e instead of the vtec motor.
On the never-ending quest for better gas mileage...
11-29-2007, 09:45 PM
#3
thanks for the help!!!
I think this is the solenoid, right? (looks like there's only 1)
here's another shot w/ the intake manifold removed (what I beleive to be the solenoid is on the right side):
11-30-2007, 05:24 AM
#4
I can't see the pics at work, but look all around on the head and see if there is a P07 stamped or marked anywhere on there.
Honda Civic VX Info/Links
Remember to use good Webiquette!
Originally Posted by ezeedee
controversy is an idea thought up by weak people who are too afraid to hear the truth.
11-30-2007, 06:22 AM
#5
Yes, that's the VTEC solenoid, but the statement earlier about VTEC and VTEC-E motors having a different number of solenoids is incorrect. Performance VTEC motors also have only one solenoid. To my knowledge, the only D-series motor with two solenoids is the two-stage VTEC D15B.
On the other hand, those intake ports look too small to be a performance-VTEC motor, so it probably is in fact a VTEC-E design.
Another thing I notice from those pics is that it appears someone has screwed a bolt in where the VTEC pressure switch should be. Maybe VTEC-E motors don't use one? Can a VX owner chime in?
11-30-2007, 08:18 AM
#6
I was trying to make sure it wasn't the two-stage model. Thanks for the input.
It sure does appear to be a vtec-e motor.
11-30-2007, 08:52 AM
#7
thanks guys...everything I've seen appears to point to a d15z1 engine, except for the "D15B" on the block itself...hopefully that's just the JDM-->USDM difference.
I should have the head off this Saturday, so hopefully that'll verify that it's a d15z1.
11-30-2007, 09:20 AM
#8
Driving on E
that's the d15z1... Japan just called it D15B, along with two other engines. the dead give aways are the "VTEC-E" on the top, as well as the smaller intake manifolid.
11-30-2007, 09:25 AM
#9
Taking the head off?
Are you rebuilding the motor? Or are you just doing it to replace the headgasket?
11-30-2007, 09:34 AM
#10
your throttle body intake looks a little bigger then I would have exspected, my vtec-e throttle body is around 2" where the flexable rubber connects to it.
most of the magic of the vtec is found under the valve cover, the 2nd set of valves ride on a rounder, insted of egg shaped lobe most of the time, then move a pin to lock it to the part of the rocker arm that is riding on a regular lobe to alow it to open the valve more, the higher performance vtec engines have all the valves ridding on regular looking lobes, and have an extra lobe that is even more aggressive for when you hit really high RPM, so if you take the valve cover off and a photo of the top side of the head then you can tell for sure.
» Car Talk & Chit Chat |
» Fuelly iOS Apps |
» Fuelly Android Apps |
